Thanks guys. The fluid I used is Valvoline synthetic Dot 3&4, NOT dot 5. It's compatible with conventional fluids, however when I built the truck all of the lines and components were new, so mixing it with old is not an issue. I'm going to try to bleed the fronts and see what happens. If there is little or no pressure, I'll replace my MC.
