wheels and tires like you say will help. my problem is I'm running 3/4 ton four wheel drive, so it won't work for me. as for a radiator, the a-body Mopars (valiant, duster etc.) from the late '60s and early '70s should work. I am running an electric fan from a 94 Buick Lesabre in front of my radiator. Still working on paint and body so haven't got the full road test in yet.
Monster,
My problem is that the temp. keeps going up even while going down the road, and that it even does it in winter, just slower. I can only go 4 or 5 miles before it starts getting above 210 degrees. I'm not seeing any water in my oil, and not many bubbles in my radiator, and the radiator seems to be flowing good and getting hot all over like it should. Should I be looking for a problem elsewhere? The radiator looks like it should be big enough and bigger than the stock radiator. I'm going to try taking some pics of my setup and post a link to them soon so you guys can take a look if you wouldn't mind.
Thanks for the response,
Jason
