Longbox, I tried your suggestion and the turn signals are very bright now. The Park lights work also but are just a bit yellow instead of white. May be my battery is down. I did this without a ground as you suggested. Thanks for you help, you saved me alot of aggravation. Boy, this site has helped me a lot over the years.
