| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55703 01/29/2006 11:32 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The flywheel diameter where the ring gear presses on is a different size between 6 and 12 volt, so you will need to use a 6 volt flywheel if you want to use a 6 volt starter and a 12 volt flywheel with a 12 volt starter. 1955-59 trucks used a foot starter if you want to use a 12 volt set-up, although a 6 volt starter works fine on 12 volts. As far as flywheel diameters between 9" and 11" clutch the outside diameter is the same the only difference is where the flywheel is drilled for the pressure plate.
See the USA in your vintage Chevrolet! My Blog | | |
