| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | It's been a while since I posted and need to do a little updating. My Grandson an I have completed the installation of an'87 Suburban front crossmember which gave us power disc brakes; we swapped out a '72 rear end to provide a 5-hole pattern front and rear. We drilled the rivets out of the crossmember and removed it to allow installation of a Chev 327/T350 using an aftermarket crossmember for the tranny mount. Two questions 1) what have you guys done to modify the emergency brake system and 2) it appears we can use a 1-piece driveshaft without cutting the "oval", is this true? Help appreciated. | | |
