Originally Posted by Spanky432
well I found the adjustment on the rod under the dash and it was out as far as it could go. Not sure where to goto next.
Throw-out bearing, clutch pivot ball inside the bellhousing.
And make sure you looked at the correct rod under the dash... it's the one on the passenger side. I confused it with the brake rod once.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
