7 members (MRMEROTH11, Wickedbass, GradyB, SWEET, TexasJim50, klhansen, 1 invisible),
67
2
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Also what engine are you using as you will need to mount the power steering pump on the engine. If you have a V8 you should be set as there are brackets out there, if its a inline 6 it a little bit harder as there isn't any brackets manufactured for the inline 6. I will talk more once I see what you have. | | |
