Here's some more info. I did a complete brake rebuild front and rear. Breaking was fine but just harder on the old leg. I added power steering and while I was at it, I figured i'd use a booster. Installed the set up and had poor braking response. When I did stand on the brakes the rear's would lock well before the front. overall I had very soft brakes.
Right now I have the engine out and front clip off I'm repainting the firewall and front frame rails and have disassembled the a-arms to be repainted. while everything is apart, I figured its easier now to work on the brakes and plumbing.
