10 members (stlcardinalsguy, joe apple, Wally / Montana, King Kielbasa, Hotrod Lincoln, Otto Skorzeny, DennisM, Wayne67vert, kades51, 1 invisible),
87
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | I got around to unsticking my heat riser and now I have a question. I read every post on the subject on here and have looked at the shop manual but am still confused.
1. With the engine cold in what position should the counter weight be when you hook the spring up?
2. Does the counter weight move to towards the engine when it gets hot and if so how far? mine hits the manifold with no spring attached, should that happen?
3. When I let the counter weight drop away from the engine it has a hard stop and the. Is that open or closed?
If someone had a picture that would be even better! thanks for your help!
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
