0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The problem with hyd lifter 235 now days is that there are no reliable hyd lifters being mfg. I had lots of probs with mine and swapped to a solid lifter set up. Unless your lifters are NOS GM pieces you may be in for some problems. Those 54 motors are perfect to swap in a pre 55 chevy with the high water pump and getting hard to find. Best of luck | | |
