| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | What you are describing here is the same thing I was thinking I had a ford motor do that many years ago and it was the guides.
Anyway what you are saying is that because the smoke only comes out when I let up on the gas it has to be a problem with the head is that right? The lower part of the engine is fine is that right? | | |
