| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I am looking at a radiator on a site, here i sthe exact one: http://www.speedwaymotors.com/Speedway-Chevy-Aluminum-Radiators,3557.html
It would fit in my 51 gmc if I turned it sideways and bought the plug for the filler and then put a new filler cap directly into a splice on the upper radiator hose. Is this realistic to do? The only thing I don't understand is: can you use a radiator in any position? Sideways/slantwaysupside down, right side up etc?? That will answer my question. Thanks.
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
