The kit came with 2 needle-and-seat sets, one solid and one spring-loaded. The one that came out had a spring, so that's the one I used. It looked taller than the original... I'll compare them when I take it apart today.
When I said I'd increase the float height, I meant with the air horn upside down, as when checking the setting. I'm hoping that keeping the fuel level lower in the bowl might help with the mixture issue...
Wish me luck.
Current fleet (subject to change w/o notice)
\'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run.
My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787.
Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
