| | | Forums66 Topics128,007 Posts1,055,275 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I am familiar decoding the NORMAL factory engine assembly serial number found on machined pad at the base of the distributor. However, when it deviates from the normal factory coding, I haven't found a source to decode it.
Here's my example. I have a 1959 235 6cylinder engine. The engine serial number is "12745 er CAL".
I believe this is a "replacement" engine. Not sure if GM replacement or from some engine rebuilder shop.
Does anyone know where there is documentation on this type of coding? I would like to learn more.
Thanks, Brian
Entire Thread
235 engine serial number decoding
| colettesbro | 03/24/2009 3:09 PM | |
