9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#5164 03/14/2004 11:56 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Easy Jason, not so quick. There is another way to gain good twin carb performance. Use the Weber style 2 bbl which have a secondary built into them. I think this is a much better way to gain both power and economy w/o going to the "hard to tune" 3-5 carbs you see in books. The internal upfits should also be done of course to take advantage of the increased fuel mixture. Probably the easiest thing you can do is put on a dual exhaust manifold. You fail to mention what engine you have. You'd be surprised what can be obtained from an old inline 6. If yours could use an overhaul anyway then it makes sense to upgrade in "innerds". | | |
