| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | And to add to your question, can they put a Heidt's (or any other kind of kit MII front end or 4 link rear) on wrong, yes they can.
If the front crossmember is not at the right angle, the anti-dive will be messed up. A common problem with the 4 link is improper pinion angle set up.
Both can be welded in place and just be wrong. There is also the ability to mess up the axle centerlines and improperly alter the wheelbase, plus just get it not square or not in the center of the frame (the front crossmember or the rear axle).
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
