The original set up included no filter other than the screen in the sediment bowl on the fuel pump. I've since added an in-line filter near the carb and will add a second one before the pump before I put everything back together. I can see how easy it is for junk to build up at the outlet given that there is no screen there at all.
1935 Chevrolet 1.5-ton 1963 Oldsmobile Dynamic 88 2-door
1965 **** F-250
1980 "Honda-Davidson" CB-750 Custom
1989 BMW 325i Convertible (wife's car)
