8 members (homer52, tclederman, Gdads51, Mike B, 78buckshot, Sjm, TooMany2count, 52Carl),
95
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,263 Posts1,058,333 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 3 speed or 4 speed? Sometimes it helps to turn the output shaft a little bit to line it up with the disc. Some shaking may make the difference as well. Usually the rear of the transmission is hanging to far down. This causes the pilot shaft to hit the pilot bearing/bushing. Try lifting the tail of the transmission and pushing it in.
Another trick is to use 1/2 inch 13 thread rod on the top 2 holes. You can then suck the transmission into place with some 1/2 inch 13 nuts. | | |
