truckernix would you do me a favor please? The part bent on my one ton is the part from the front spring hanger to the bumper. Looking at it head on the horn, I'll call it, is bent away from the center a good inch. The right side however is straight ahead. The frame is still attached to the bumper. If corrected would the two horns be parallel or are they farther apart at the front or bumper end? I don't know if I need to move the left one in and the right one out a little or leave the right one alone. I need someone to look at a one ton and advise me. Thanks----
