Some will, some won't. I'm sure others here can give you a better list. I think the offy will. However, it is an aluminum intake and will carbonize eventually from the exhaust heat. Some say that it is better to heat an aluminum intake with water. A vintage cast iron intake like the old edelrock or tattersfield will mate right up with your old exhaust mainifold. The old edmunds will not and is already set up to be water heated.
