| | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The 3 speed transmission with column shift was standard equipment on the 3/4 ton. I believe the 1/2 and 3/4 ton 3 speeds are the same. The U-joints are different, however and I think the rear bearing retainer is different on the 3/4 ton. At the very least you would need a 3/4 ton 3 speed U-joint.
