4 members (WICruiser, dwreills, 78buckshot, Shardean), 93 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#507429 02/18/2009 8:39 PM
I'm wanting to put the original 3 speed back in my 51 3/4 ton. It has a 4 speed in it now. Is a 1/2 ton 3 speed the same as a 3/4 ton? Someone told me they may be different.
Thanks for any help.
It may not go fast, but it does look good!
1950 chevy 3100
dads51 #507440 02/18/2009 9:42 PM
I think 3/4 tons only came with a 4 speed. Others will confirm or correct this.
58' 3200 235 3-speed/OD
ApacheFiend #507446 02/18/2009 9:53 PM
The 3 speed transmission with column shift was standard equipment on the 3/4 ton.
I believe the 1/2 and 3/4 ton 3 speeds are the same.
The U-joints are different, however and I think the rear bearing retainer is different on the 3/4 ton.
At the very least you would need a 3/4 ton 3 speed U-joint.
Steve
'49 3800
'52 3600
'57 3100
Ghostrider #507465 02/18/2009 10:26 PM
ok, thanks for the info, I know it had a 3 speed stock, but my dad had changed it out at somtime or another, it still had the shift box on the column and stuff. Thanks again
1950 chevy 3100
