| | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50642 09/28/2005 10:28 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Pull the coil wire out of the center of the dist. & set it a little way away from the engine . Turn engine over with key on. You should get a blue spark from the wire to ground about 1/4 in. If not remove dist. cap & with key on put a screwdriver on points & each time points are open & closed or grounded you should get a little spark at the points & a spark at the coil wire. Check the connection at the points. If you don,t get the wire on straight it can short to the breaker plate. If the point gap is set right the dwell will be real close to right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
