0 members (),
182
3
Mod | | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50625 09/28/2005 5:04 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | From hard experience I can tell you to also put a little non-hardening sealer on the cap screw threads that hold the front bearing retainer and shift plate.
I had to pull mine back out because trans oil would leak out around the threads.
Paul | | |
