2 members (TUTS 59, 1 invisible),
192
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50509 09/26/2005 1:36 AM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Here is one more option. In my 46 1/2 ton I swapped out the center pumpkin for one from an open driveline 56 1/2 ton. The pumpkin will bolt right in to the old housing. I then welded in new solid type spring perches. It worked good for me because I kept my old housing and the e-brake stayed. I also kept 6 lug all around. The pumpkin from the 56 had 3:38 gears. I'm running a 283 with a TH350 and it has held up fine so far. | | | |
Entire Thread
engine, trans and rearend swap 1950 truck
| chevy 50 | 09/25/2005 1:06 PM |
Re: engine, trans and rearend swap 1950 truck
| dale937 | 09/25/2005 2:00 PM |
| Bill Schickling | 09/25/2005 2:14 PM |
| OldSub | 09/25/2005 4:48 PM |
| gaffbro | 09/25/2005 5:44 PM |
| OldSub | 09/25/2005 10:16 PM |
| chevy 50 | 09/26/2005 1:00 AM |
| Rick Rickard | 09/26/2005 1:36 AM |
| OldSub | 09/26/2005 1:52 AM |
| Curly #1 | 09/29/2005 8:18 PM |
| Jed | 09/29/2005 8:47 PM |
| Fumblin46 | 09/29/2005 10:09 PM |
| Jed | 09/29/2005 11:09 PM | |
