| | | Forums66 Topics128,052 Posts1,055,726 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | someone cut the frame short to put a homemade deck on? the rear cross sill is turned around? you have the other cross sills in the wrong holes? how much room between the front bed panel and the back of the cab? [should be nearly touching]
the 55-66 bed is the same but some years hit the frame at slightly different points, and there's extra holes in most year frames
Bill | | |
