Where do you feel the vibration?
If it is felt in the steering wheel more that cab parts, it is front wheels. If you feel it in the cab floor stronger than other places, it may be rear wheel balance.
Normally, driveline vibrations, especially u-joints, will change intensity with acceleration, cruise or trailing throttle.
Post back with more info after a test drive.
