BeCool Radiators Very good product ask any street rodder. Be sure and put a good electric fan with it. The best as far as I am concerned Spal a very good product made in Italy! It has lots of rated CFM's! Biggest in the industry for its size. I also suggest to run a separate Tranny Cooler less hassels on cooling the tranny. Just remembered use a true street Radiator and not a racing type. Get the one inch tube model and if you use a down flow make sure it goes up and down for twice the cooling effect meaning the tubes are inter conected fron top to bottom to exit. This will cost a little extra but worth the extra cash.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
