Ron, do you have carter yf or rochester, if you have carter I might be interested in buying it,,, I am not so sure that the carb is your problem,,,I may be nuts but I have never had a carb backfire as you describe, seems like mine have always been electrical but I am no expert, by moving the dist and making it run better may seem to support that it may not be the carb.. good luck and let us know, I know how you feel, it is nerve racking to try and fix somthing and not be able to do it and have to take it to a mech,, I know just enough about these old trucks to be dangerous,,, take care........Fred
Redryder pix
My Hotrod
