| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50084 09/16/2005 6:21 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Too bad you are not nearby as I have 9 axle shafts for that era. What you have to look for is wear at the point the seal sits on the shaft as if worn it will leak. As for seals there are two tmanufacturers, one is Chicago Rawhide C/R and the other is National. One is really much beefier than the other (I think it is National) and a better choice. | | |
