| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Take your time. Ensure that all crimped connections are solid - ie. yank on them !. Use grommets where you pass thru metal. Spliced wires should be soldered. I used heat shrink tubing on the splices as well for extra protection. Make sure your ground connections are good & solid. Run ground cables from motor to frame and body points. | | |
