Yes you did the right thing cutting a channel in the gasket to the vacuum hole. Read your plugs like Arny said & if it,s running rich take the top off the carb. & check the float level & make shure the power valve plunger goes up & down & opens the ball. These are simple little carbs & work great when you get it right. Check the timing & make shure the vacuum advance is working. smile
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
