| | | Forums66 Topics128,268 Posts1,058,193 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Your bellhousing will not fit, in fact hardly anything from the 235 will interchange with the 250. You need the 55-67 V-8 truck bellhousing (also 63-67 6 cyl). The 250 engine has center mounts, pick up a tubular crossmember mount (same as V-8) from any of the aftermarket suppliers. FRed
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
