| | | Forums66 Topics128,042 Posts1,055,602 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | If it cranks over and always eventually starts, I'd check the fuel pump relay on the firewall. If this relay fails, the Control Module senses the fault and provides +12 volts from another source (I believe from the oil pressure sensor, once oil pressure is detected). | | |
