| | | Forums66 Topics128,157 Posts1,056,872 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I believe the Weber versions of this carb uses the same jets as the H/W (may want to ask Tom about that). Search the internet for Weber carbs and ask around, several dealers around, I've seen high dollar kits for Jeeps etc. Also you can drill out your H/W jets. I'll have to check my files to see what size I used on my 261 dual set up. Send me a private message and I'll get back to you later. | | |
