| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Rear ends are totally different between a 1/2 and 3/4 ton,look at 67 to 72 3/4 tons to get taller gears and the center section will bolt in. You can find the gear ratios by looking on the inside of the glove box door usually as it has the options. Jeff | | | |
Entire Thread
1952-216, Engine
| cshamel | 01/02/2009 3:41 AM |
Re: 1952-216, Engine
| waldo53 | 01/02/2009 3:55 AM |
| cshamel | 01/02/2009 3:59 AM |
| waldo53 | 01/02/2009 4:01 AM |
| cshamel | 01/02/2009 4:08 AM |
| Hotrod Lincoln | 01/02/2009 4:12 AM |
| Ghostrider | 01/02/2009 4:29 AM |
| Achipmunk | 01/02/2009 5:00 AM |
| cshamel | 01/02/2009 5:30 AM |
| Hotrod Lincoln | 01/02/2009 6:00 AM |
| hotshoe36 | 01/02/2009 1:25 PM |
| GMCdp | 01/02/2009 6:51 PM |
| Jeff Ogden | 01/04/2009 1:53 AM |
| Ghostrider | 01/02/2009 4:09 AM |
| bigedpa | 01/03/2009 12:27 AM |
| waldo53 | 01/03/2009 12:33 AM | |
