| | | Forums66 Topics128,014 Posts1,055,331 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Unless you're planning on a complete restoration to original equipment condition, I'd suggest an upgrade to the 54-up 235 engine with a little camouflage to make it look like the 216 to the casual observer. The top-bolt valve cover and the high-mount water pump adapter makes the high pressure engine look original to the casual observer.
It's going to be very expensive to convert the 216 to full-pressure oiling, and you won't have much of an advantage over the splash-oiled engine when it's all done. Millions of splash oilers ran for a lot of years under tougher operating conditions than the average restored stovebolt encounters. A good original-specification buildup, possibly with the rods machined for insert bearings, would be very reliable without going to the effort and shipping expense of the conversion job. The 3.55:1 ring & pinion will help the cruise speed and you can keep the original-looking closed driveline system. Jerry
Edit: No help on the 3/4 ton gear ratio- - - -there's no highway-cruise gear available for that one. You would need a transmission and rear end change to get more road speed. Jerry
Entire Thread
1952-216, Engine
| cshamel | 01/02/2009 3:41 AM |
Re: 1952-216, Engine
| waldo53 | 01/02/2009 3:55 AM |
| cshamel | 01/02/2009 3:59 AM |
| waldo53 | 01/02/2009 4:01 AM |
| cshamel | 01/02/2009 4:08 AM |
| Hotrod Lincoln | 01/02/2009 4:12 AM |
| Ghostrider | 01/02/2009 4:29 AM |
| Achipmunk | 01/02/2009 5:00 AM |
| cshamel | 01/02/2009 5:30 AM |
| Hotrod Lincoln | 01/02/2009 6:00 AM |
| hotshoe36 | 01/02/2009 1:25 PM |
| GMCdp | 01/02/2009 6:51 PM |
| Jeff Ogden | 01/04/2009 1:53 AM |
| Ghostrider | 01/02/2009 4:09 AM |
| bigedpa | 01/03/2009 12:27 AM |
| waldo53 | 01/03/2009 12:33 AM | |
