| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter sells the simplest (HPM544) intake manifold heater kit. It will work fine with a standard intake manifold. Some people use water but it is more complicated and the water does not truly circulate unless the intake manifold (and plate) are set up for circulation throughout the intake manifold. Clifford intakes and Offenhauser intakes will circulate water with the correct heat plate kit (Tom Langdon's kit (that I bought this past summer) will not circulate properly with these two types of water-heated intakes). | | |
