| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 33 New Guy | | New Guy Joined: Jul 2007 Posts: 33 | Santa has arrived and I just got some headers for my my 54 3100 with 61 235. I'm running the factory intake and I was wondering how I need need to plumb a heat tube from the bung on the header to the intake. Do I need to just fabricate a plate to block of the bottom of the intake and run a pipe out? Anyone have pics or ideas of how they heat their intakes? thanks | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Several of the vendors make a heat kit that you can just bolt on. You can also get one from Tom Langdon. You could make your own if you prefer. The catalogs will show a picture so you can get an idea what's involved. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim Carter sells the simplest (HPM544) intake manifold heater kit. It will work fine with a standard intake manifold. Some people use water but it is more complicated and the water does not truly circulate unless the intake manifold (and plate) are set up for circulation throughout the intake manifold. Clifford intakes and Offenhauser intakes will circulate water with the correct heat plate kit (Tom Langdon's kit (that I bought this past summer) will not circulate properly with these two types of water-heated intakes). | | |
