| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i put an ez wiring harness in my 46 i came with a horn relay. i also replaced the steering mast bearing and horn parts in the wheel. is there a way to use the relay in my harness with the old horn button? as i see it now my options are wire the horn up just like gm did and call it good, add an ugly horn button, or make the old button work the relay. any thoughts? philip | | |
