8 members (cmayna, 5 Window 9434, Opelika Tom, TooMany2count, Otto Skorzeny, JW51, Gib70, mk72),
84
2
Mod | | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Have the truck scanned to make sure you don't have a sensor bad causing the lockup or a bad solenoid in the transmission. The torque converter solenoid may not be operaing correctly and when the fluid is cold it doesn't flow through as quickly. If the fluid looks and smells burnt you have deeper troubles.
That truck will tell you a lot about what is happening through the computer and a scanner.
But be ready, usually if you are having that kind of trouble, there is a deeper underlying cause. | | |
