2 members (dt235sd, 1 invisible),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47782 07/17/2005 4:41 PM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It sounds to me like you've got a bent backing plate. If the drum was warped, the tight spot would rotate with the drum. Pull the drum and the brake shoes back off, down to a bare spindle and backing plate, and do some measuring from the end of the spindle to various points around the edge of the backing plate. If it's bent, straightening it might be a real challenge. I'd expect uneven brake shoe wear if it's allowed to stay out of alignment. Jerry
