| | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Check fuel filter again, possible bad fuel pump or bad carb. Take the top off of the carb and spray some carb cleaner in there and wipe it out. Could be a sticking float, dried out accelerator pump or crud settled in the bowl. Best to rebuild the carburetor anyways.
Does it run at idle?
What happens if you feed gas by hand while it is running? | | | |
Entire Thread
Running, but need a little help
| Truck-man | 11/25/2008 12:24 AM |
Re: Running, but need a little help
| GMONIZ | 11/25/2008 2:34 AM |
| Truck-man | 11/25/2008 3:05 AM |
| neilroy | 11/25/2008 3:46 AM |
| blackjack62 | 11/25/2008 4:02 AM |
| GMONIZ | 11/25/2008 8:16 PM |
| Truck-man | 11/26/2008 12:47 AM |
| GMONIZ | 11/26/2008 1:26 AM |
| Truck-man | 11/26/2008 1:56 AM |
| GMONIZ | 11/27/2008 5:53 AM | |
