That's actually the way the thing is supposed to be. If you are not getting enough oil to the rockers then the tube/passage from the cam bearings up to the head is clogged.
If the thing was just rebuilt make sure the rocker shafts are the right way around. The oil holes go up.
Paint & Body Shop moderator
