0 members (),
130
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 Apprentice | | Apprentice Joined: May 2008 Posts: 34 | Denny: Could it be possible at your getting some seepage at the oil line that feeds the rocker arms doesn't that go though the water jacket maybe the solder joint on the fitting has cracked. I think if were a cracked head you would have a lot of smoke and water dripping from the tail pipe. If you can get hold of a radiator presser pump takeing out the spark plugs and pumping up the cooling system and spinning it over water should come out a spark plug hole if the heads cracked Just a thought
Paul | | | |
Entire Thread
I’m Dead in the Water, rather Dead from the Water!
| Denny Graham | 10/30/2008 4:23 PM |
Re: I’m Dead in the Water, rather Dead from the Water!
| Toyvo | 10/30/2008 4:36 PM |
| Harvester | 10/30/2008 5:03 PM |
| Hotrod Lincoln | 10/30/2008 5:52 PM |
| Denny Graham | 10/30/2008 10:01 PM |
| Jeff Ogden | 10/30/2008 11:52 PM |
| 46Canopy | 10/31/2008 1:47 AM |
| truckernix | 10/31/2008 2:37 AM |
| Denny Graham | 10/31/2008 3:53 AM |
| crenwelge | 10/31/2008 4:39 AM |
| truckernix | 10/31/2008 11:37 AM |
| Roy Rodgers | 10/31/2008 12:32 PM |
| 31,32,33 | 10/31/2008 1:48 PM |
| Denny Graham | 10/31/2008 2:39 PM |
| truckernix | 10/31/2008 2:58 PM |
| SW_Radial | 10/31/2008 3:17 PM |
| Denny Graham | 10/31/2008 3:28 PM |
| crenwelge | 10/31/2008 5:53 PM |
| truckernix | 10/31/2008 8:22 PM |
| neilroy | 10/31/2008 9:25 PM |
| Denny Graham | 10/31/2008 10:33 PM |
| Paul Palm | 11/01/2008 12:46 AM |
| Denny Graham | 11/01/2008 2:13 AM |
| Paul Palm | 11/01/2008 6:06 PM |
| crenwelge | 11/01/2008 7:15 PM |
| truckernix | 11/01/2008 7:52 PM |
| Denny Graham | 11/02/2008 4:49 AM |
| 4ontheFloor | 11/04/2008 1:42 AM |
| Denny Graham | 11/04/2008 4:01 AM |
| crenwelge | 11/04/2008 5:14 AM |
| Denny Graham | 11/04/2008 2:34 PM |
| Denny Graham | 11/08/2008 11:21 PM |
| don stocker | 11/08/2008 11:44 PM |
| neilroy | 11/09/2008 12:57 AM |
| Achipmunk | 11/09/2008 4:41 AM |
| Hotrod Lincoln | 11/09/2008 6:09 AM |
| 46Canopy | 11/09/2008 5:19 PM |
| crenwelge | 11/09/2008 7:24 PM |
| truckernix | 11/09/2008 7:26 PM |
| papaterk | 11/09/2008 7:52 PM |
| Denny Graham | 11/10/2008 1:38 AM | |
