| | | Forums66 Topics128,186 Posts1,057,308 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The pressure testing that I mentioned is a standard cylinder head pressure test that any well equipped head shop should have. That's why I'm 99% sure that if the head is leaking it will show up in No.3 combustion chamber when I do get the head off. In the mean time when I get a chance I'm gonna do a cylinder leak down test just to see if I can nail it before I tear it down. I have to machine a new adaptor for the 14mm plugs, the only ones I've got made up are for the tapered plugs and the 18mm plugs that are in the Lycoming in my Pitts. I used to do a leak down test on it every time I did my annual inspection. Anyway you look at it, it's a bummer. Before I decided to go ahead and use this head I got three other ones (the same casting number) and two of the three had more cracks than my original head, the third one had no cracks but did have some very large ugly deep pits on a couple of cylinders which showed up once we got it out of the dip tank. I sunk another $450 into it so I’m hoping that one should be OK. Denny Graham Sandwich, IL
Denny G Sandwich, IL
Entire Thread
I’m Dead in the Water, rather Dead from the Water!
| Denny Graham | 10/30/2008 4:23 PM |
Re: I’m Dead in the Water, rather Dead from the Water!
| Toyvo | 10/30/2008 4:36 PM |
| Harvester | 10/30/2008 5:03 PM |
| Hotrod Lincoln | 10/30/2008 5:52 PM |
| Denny Graham | 10/30/2008 10:01 PM |
| Jeff Ogden | 10/30/2008 11:52 PM |
| 46Canopy | 10/31/2008 1:47 AM |
| truckernix | 10/31/2008 2:37 AM |
| Denny Graham | 10/31/2008 3:53 AM |
| crenwelge | 10/31/2008 4:39 AM |
| truckernix | 10/31/2008 11:37 AM |
| Roy Rodgers | 10/31/2008 12:32 PM |
| 31,32,33 | 10/31/2008 1:48 PM |
| Denny Graham | 10/31/2008 2:39 PM |
| truckernix | 10/31/2008 2:58 PM |
| SW_Radial | 10/31/2008 3:17 PM |
| Denny Graham | 10/31/2008 3:28 PM |
| crenwelge | 10/31/2008 5:53 PM |
| truckernix | 10/31/2008 8:22 PM |
| neilroy | 10/31/2008 9:25 PM |
| Denny Graham | 10/31/2008 10:33 PM |
| Paul Palm | 11/01/2008 12:46 AM |
| Denny Graham | 11/01/2008 2:13 AM |
| Paul Palm | 11/01/2008 6:06 PM |
| crenwelge | 11/01/2008 7:15 PM |
| truckernix | 11/01/2008 7:52 PM |
| Denny Graham | 11/02/2008 4:49 AM |
| 4ontheFloor | 11/04/2008 1:42 AM |
| Denny Graham | 11/04/2008 4:01 AM |
| crenwelge | 11/04/2008 5:14 AM |
| Denny Graham | 11/04/2008 2:34 PM |
| Denny Graham | 11/08/2008 11:21 PM |
| don stocker | 11/08/2008 11:44 PM |
| neilroy | 11/09/2008 12:57 AM |
| Achipmunk | 11/09/2008 4:41 AM |
| Hotrod Lincoln | 11/09/2008 6:09 AM |
| 46Canopy | 11/09/2008 5:19 PM |
| crenwelge | 11/09/2008 7:24 PM |
| truckernix | 11/09/2008 7:26 PM |
| papaterk | 11/09/2008 7:52 PM |
| Denny Graham | 11/10/2008 1:38 AM | |
