| | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Denny, I've done an in-the-frame leak check that doesn't involve a teardown to locate, or at least confirm the presence of a leak on some of my race engines. They're prone to develop pinhole leaks in cylinder walls that get bored way oversize due to casting flaws, and they don't show up until they've been run hard for awhile.
Disconnect and plug off both radiator hose nipples with expanding rubber freeze plugs, and figure out a way to plug one heater hose connection, usually with a threaded-in pipe plug. Adapt the other heater hose connection to a garden hose, and turn city water pressure into the block/head assembly. Leave it pressurized for several hours. A seep leak will either fill up a cylinder, or show a leak into the crankcase after sitting awhile. Id this procedure doesn't show an exact location for the leak, at least it will point you in the right general direction. Jerry
Entire Thread
I’m Dead in the Water, rather Dead from the Water!
| Denny Graham | 10/30/2008 4:23 PM |
Re: I’m Dead in the Water, rather Dead from the Water!
| Toyvo | 10/30/2008 4:36 PM |
| Harvester | 10/30/2008 5:03 PM |
| Hotrod Lincoln | 10/30/2008 5:52 PM |
| Denny Graham | 10/30/2008 10:01 PM |
| Jeff Ogden | 10/30/2008 11:52 PM |
| 46Canopy | 10/31/2008 1:47 AM |
| truckernix | 10/31/2008 2:37 AM |
| Denny Graham | 10/31/2008 3:53 AM |
| crenwelge | 10/31/2008 4:39 AM |
| truckernix | 10/31/2008 11:37 AM |
| Roy Rodgers | 10/31/2008 12:32 PM |
| 31,32,33 | 10/31/2008 1:48 PM |
| Denny Graham | 10/31/2008 2:39 PM |
| truckernix | 10/31/2008 2:58 PM |
| SW_Radial | 10/31/2008 3:17 PM |
| Denny Graham | 10/31/2008 3:28 PM |
| crenwelge | 10/31/2008 5:53 PM |
| truckernix | 10/31/2008 8:22 PM |
| neilroy | 10/31/2008 9:25 PM |
| Denny Graham | 10/31/2008 10:33 PM |
| Paul Palm | 11/01/2008 12:46 AM |
| Denny Graham | 11/01/2008 2:13 AM |
| Paul Palm | 11/01/2008 6:06 PM |
| crenwelge | 11/01/2008 7:15 PM |
| truckernix | 11/01/2008 7:52 PM |
| Denny Graham | 11/02/2008 4:49 AM |
| 4ontheFloor | 11/04/2008 1:42 AM |
| Denny Graham | 11/04/2008 4:01 AM |
| crenwelge | 11/04/2008 5:14 AM |
| Denny Graham | 11/04/2008 2:34 PM |
| Denny Graham | 11/08/2008 11:21 PM |
| don stocker | 11/08/2008 11:44 PM |
| neilroy | 11/09/2008 12:57 AM |
| Achipmunk | 11/09/2008 4:41 AM |
| Hotrod Lincoln | 11/09/2008 6:09 AM |
| 46Canopy | 11/09/2008 5:19 PM |
| crenwelge | 11/09/2008 7:24 PM |
| truckernix | 11/09/2008 7:26 PM |
| papaterk | 11/09/2008 7:52 PM |
| Denny Graham | 11/10/2008 1:38 AM | |
