| | | Forums66 Topics128,186 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Denny, your valve cover indicates a leak, as you already suspect. Surface cracks have a way of progressing, so my guess is yours finally reached the water jacket. It sounds like you did a cylinder leakage test on the engine in the past. I would do that again. My limited experience with cast iron cracks is 1) they don't stop; 2) they are hard to repair, but repair is often possible. Good luck with your situation, and let us know what you find.
Harvester | | | |
Entire Thread
I’m Dead in the Water, rather Dead from the Water!
| Denny Graham | 10/30/2008 4:23 PM |
Re: I’m Dead in the Water, rather Dead from the Water!
| Toyvo | 10/30/2008 4:36 PM |
| Harvester | 10/30/2008 5:03 PM |
| Hotrod Lincoln | 10/30/2008 5:52 PM |
| Denny Graham | 10/30/2008 10:01 PM |
| Jeff Ogden | 10/30/2008 11:52 PM |
| 46Canopy | 10/31/2008 1:47 AM |
| truckernix | 10/31/2008 2:37 AM |
| Denny Graham | 10/31/2008 3:53 AM |
| crenwelge | 10/31/2008 4:39 AM |
| truckernix | 10/31/2008 11:37 AM |
| Roy Rodgers | 10/31/2008 12:32 PM |
| 31,32,33 | 10/31/2008 1:48 PM |
| Denny Graham | 10/31/2008 2:39 PM |
| truckernix | 10/31/2008 2:58 PM |
| SW_Radial | 10/31/2008 3:17 PM |
| Denny Graham | 10/31/2008 3:28 PM |
| crenwelge | 10/31/2008 5:53 PM |
| truckernix | 10/31/2008 8:22 PM |
| neilroy | 10/31/2008 9:25 PM |
| Denny Graham | 10/31/2008 10:33 PM |
| Paul Palm | 11/01/2008 12:46 AM |
| Denny Graham | 11/01/2008 2:13 AM |
| Paul Palm | 11/01/2008 6:06 PM |
| crenwelge | 11/01/2008 7:15 PM |
| truckernix | 11/01/2008 7:52 PM |
| Denny Graham | 11/02/2008 4:49 AM |
| 4ontheFloor | 11/04/2008 1:42 AM |
| Denny Graham | 11/04/2008 4:01 AM |
| crenwelge | 11/04/2008 5:14 AM |
| Denny Graham | 11/04/2008 2:34 PM |
| Denny Graham | 11/08/2008 11:21 PM |
| don stocker | 11/08/2008 11:44 PM |
| neilroy | 11/09/2008 12:57 AM |
| Achipmunk | 11/09/2008 4:41 AM |
| Hotrod Lincoln | 11/09/2008 6:09 AM |
| 46Canopy | 11/09/2008 5:19 PM |
| crenwelge | 11/09/2008 7:24 PM |
| truckernix | 11/09/2008 7:26 PM |
| papaterk | 11/09/2008 7:52 PM |
| Denny Graham | 11/10/2008 1:38 AM | |
