Can someone, anyone give me some tips on filling brake system on a 58 step side? System is all stock with everything new from master cyl, lines, to wheel cylinders.
Should I start at right rear,then left rear, then right front and end at left front?
Can I put a hose on 1 wheel cylinder and into a container so I can stay at master cylinder and add fluid as it is pumped into the lines and wheel cylinders? Then when I get fluid out of the line, close the valve and go to the next wheel. When all 4 wheels and lines are basically full, I can rebleed with the typical 2 person operation?
