| | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Steel pan should weld up fine use a Mig or Tig and get everything as clean as possible. Concerns may be is the pinhole from damage or corrosion? If corrosion you may have more than just a pinhole once you strike an arc on it. One sure fire way to make a repair is make a small patch and weld over the hole. This should get you to good metal and prevent further opening of the already damaged area. Before you reinstall fill the pan with water and let it sit for a period of time to see if the repair took, any signs of weeping indicate you missed something. | | |
